I have a BlueDriver Pro. Any feedback on trouble code P2096 (exhaust issue)? Car runs fine.
Trouble code B00A0 frosts me. Problem: seat belt light illuminated when passenger seat is empty. It seems only the dealer can do a zero point reset using their exclusive ‘consult’ program. Probably a good idea to leave alone?
P2096 trouble code definition. In the simplest of terms, the P2096 fault code indicates the Powertrain Control Module (PCM) has received data from the oxygen sensors in the exhaust system that there is an excess of air and shortage of fuel within the number one cylinder.
'Post Catalyst Fuel Trim System Too Lean Bank 1'
Not for cylinder 1, BANK 1 which is a four cylinder engine. The ECM cannot tell which cylinder is lean yet, only which is misfiring due to multiple coils, there are no multiple O2 sensors one for each cylinder yet.
The code is for AFTER the cat as well which has nothing to do with engine conditions in and of themselves. Possible air leak between engine and cat or electrical issue with wiring or connector maybe. Could be the sensor too.
The seat belt code is actually for the weight sensor under passenger seat, it is probably erroneously showing weight like a passenger is there and likely looking for the seat belt to be connected as a result.
