Hello all,
I have had next to no issues with my 2019 base model versa with the 5MT, although it seems that the transmission will decide to randomly fight going into first or second, requiring me to quite literally mash it into gear. Has anybody else had something similar? It only happens here and there and I haven't had it happen in a month or so now but it bothers me.
It could be a couple of things. You might want to have the transmission linkage checked to make sure that everything is within specs.. Another possibility could be that the clutch pedal may need to be adjusted, but If it hasn't happened in over a month that might not be the issue. Usually when you have to mash it into gear, if it were an older car, it might be a worn syncro or throw out bearing. Good luck!!
As an experiment, you may want to try double clutching when going from 1st to 2nd and see if you can duplicate the "mashing" or "fighting".
