I'm trying find the location of trunk lamp so I can buy the assembly at the dealership worth $18. I spoke with the service rep. ussualy it's a taped wire that can located in the trunk.
It could be in two places. But it should be in the fuse box located behind the dash on the drivers side. If you pop out that piece below your power mirror switches you will see the fuse box. However looking at the diagram, I don't see a spot for it, and it's not in the engine fuse box. Just check to see if all the fuses are there, and if so check to see if power is going to the wire,
