Would it be a big deal to install a trunk release in my Versa S?
Have you looked to see if it is pre-wired? I was looking at my trunk latch the other day and noticed there is an wired clipped into it. I haven't traced the wired back yet, but I'm assuming one could just buy and alarm system and wire it up.Would it be a big deal to install a trunk release in my Versa S?
My 2009 Versa S sedan came with the trunk release even though the salesperson didn't think the sedan had one. It is a rubber membrane button between the two license plate lamps. What year is your S?Would it be a big deal to install a trunk release in my Versa S?
Hi Frank,My 2009 Versa S sedan came with the trunk release even though the salesperson didn't think the sedan had one. It is a rubber membrane button between the two license plate lamps. What year is your S?
Frank 2009 Versa S Sedan MT-6
Hi. New to the forum. Nothing like making my first post one where I resurrect an old thread back from the dead!Look up the pinout for the lock actuator, run wires in parallel for a switch between actuator motor, game over.
LizardV - Do you have any pics of your installs? Need to know where you mounted the actuators on the doors and power window motors./ any and all help is appreciatedOh you are so in luck. I too am a 2014 Nissan Versa S owner.
I now have installed. Power windows, locks, trunk release, alarm (keyless entry), and remote start.
I actually don't believe any versas come with a trunk release inside the car.
The way I did my trunk release is with a power lock actuator. I went this route because I believed the wires back there were for the lights.
I mounted it out of sight and all you see is a nice black wire shielding from a bike lock cable coming down and I use the "Emergency I'm stuck in the trunk" latch to open the trunk. Works very reliably and is secure. You have to do a bit of tinkering to get it right.
If you're interested in a how to. I'll write one up for you.
