1 - 20 of 20 Posts
Hello,
First off I am a new to the Nissan Versa, seems like a great little car.
I know this question has been asked but I would like clarification on a few things. I have the 2008 'S' model package with the basic 1 CD player and will be upgrading to a 6 CD player from a 2010 (see illustration).
To my understanding does one need an additional iPod harness that plugs into the back of the SL radio and into the iPod?
If so, can I use the radio trim from a newer SL (see illustration) that includes the 'usb' and aux jack and use them together for a factory look to run my iPod?
Thanks for your help.
I don't mind buying the harness. Is it a harness that goes from back of radio to ipod or back of radio to the radio bezel/trim?
Could someone post a picture of what else I'm buying besides the radio?
Discussion Starter · #6 · (Edited)
Ok so I am continuing this thread in hopes of helping others.
I now have the SL radio from a 2010 Nissan Versa SL (with ipod and AUX jack). I have posted a Side by side comparison of (top) 2010 Nissan Versa SL with ipod and Aux Radio and (bottom) 2008 Nissan Versa S Radio [note: both radios are double DIN]
I have connected (A) antennae, (C) and (E). Can someone tell me what is (B) and (D) for ?? I'm assuming one is for the ipod/bluetooth/satnav and the other is for the steering wheel volume control.
Secondly, I am now looking for the ipod harness that goes from the back of the radio to either the glasses holder or the jack near the parking brake. Specifically I am looking for the schematics of the wiring for that harness (ie. what color wires go where.)
Thank you.
doesn't seem like this question has been answered, and my questions the same anyone have anymore input?
iPod harness that plugs into the back of the SL radio and into the iPod? or something else? What are the differences in the picture above
Thank you.
I don't know about (B), but (D) looks exactly like the GPS antenna connector of my radio. Also, the steering wheel controls are wired through the (E) harness, you can find more info at http://axxessinterfaces.com/ or http://contentdocs.installernet.com/documents/vehicle/10972.pdf. You don't need that interface to connect your new radio, but you can learn more about your wires.
Hope this will help.
Ricardo
Discussion Starter · #10 ·
Can anyone chime in with the answer? I don't want to use the aux jack. i want to use the ipod full functionality, scroll through songs and have the IDE tags scroll on the display.
this has still not been answered, I put the SL radio in works great but don't want to use the AUX port, want full access to the IPOD menu and songs. What do I need to purchase?
I just removed a 13' Versa stock unit and I'm also interested in finding the Ipod harness.
(D) is for the bluetooth microphone.
My stock unit is a bit different than yours, (B) or (C) is not present (I'll check and take a picture tonight).
My project is a bit different. My plan is to hook up the stock unit to a different vehicle. I ordered harnesses Metra 71-75552 and Scosche NAA2RB and I just need the Ipod interfase.
That's not it. That's what you use to hook up the Ipod to the harness the OP is looking for.
As promised here are my unit's pictures. Mine doesn't have (C)
Summarizing:
(A) Antenna
(B) Ipod
(C) 1st gen Versa connector. CD changer (?)
(D) Bluetooth microphone
(E) Main harness
Still need to figure out how to connect (B) to the Nissan cable.
2007 Nissan Versa Hatchback SL
i believe (E) is for the cruise control. gonna work on my existing problem of it not wanting to turn on after removing my 6 cd changer. unit is good but cd player is kaput. will update soon.
Well I can tell you the steering wheel controls are in the main harness. Its just 3 wires. You can actually add them if you like. I would assume that the other 2 plugs are for the ipod/sat or bluetooth and the other might of been for the Rockford system used in the 07-09 hatchbacks. My 09 versa sedan only had 2 plugs. Main and antenna. We had an 09 hatch SL with bluetooth, but I never got to look at it.
1 - 20 of 20 Posts
