Hi everyone,
I can' t find words to describe this problem, maybe ride a horse is close but take a look and let me know, I have no idea.
https://youtu.be/VZNtTVPVlLU
https://youtu.be/6zZXH79d29I
Take a look at this and it may give you some ideas. If there are no codes showing and no "check engine light on the dash, you may have to take it into a dealership and have them diagnose the transmission to see if it is ok. As mentioned in the video, the mass Air sensor can also cause similar problems. Good luck!!
Thanks for the tip, just noticed the car was running without cvt fluid, yes 0 ml, no fluid, any way to say cero, dry transmission, but the best part is the car still running without cvt fluid, HOW? I don't know I can make a video I ram my car for 10 min on my neighborhood without the oil pan bolt, no fluid coming out and the car still the same, the stick with yellow loop have no marks of liquid, so, I have no Idea how CVT works.
If you did not remove the standpipe bolt then you still had fluid in it, the converter cannot move the car if empty of fluid.
Don't be surprised if the trans fails pretty quick now.
