Has anyone installed installed lowering springs besides the Tanabe's? Just bought a Versa Note and I'm looking to put some lowering springs and rims on this bad boy.
Get the enkei 15x8 rims on low profile tires. The stock height is low already. Low profile tires will get the note as low as it gets without changing your suspension. Then get some wider tires than stock for some better grip.
If you put smaller tires on your car, yoir spedo will be off, youll put more miles on your car then you actually drive, if uou change rims then you need to get the same diameter comnination as the stock set-up
3 Participants
D3R3K
