Hey everyone. I work at a Nissan Dealership and I am looking at maybe building a Nissan Versa B-Spec race car for use in the Pirelli World Challenge.
I am looking for parts like camber plates and non-adjustable coilovers. Does anyone know of parts available?
Thanks.
D
Discussion Starter · #2 ·
The rules for suspension are as follows:
Anyone have any suggestions for what shocks fit this??
"Suspension: competitors must use the OEM suspension or the upgraded manufactures suspension kit in its entirety, with no modifications. Competitors must use the OEM bump stops or the bump stops provided in the manufactures kit.
If a manufacture does not offer an upgrade shock and spring kit, a competitor may submit a shock and spring package for approval by the CRB. At the time of approval, that kit will become the standard for that make and model until the manufacture submits a factory supported kit.
The competitor supplied kits needs to be comprised of the following:
• Any non-adjustable shock absorber intended for the specific make model and year car is allowed. The shock absorber must be installed in the original mounting locations. Remote shocks are not permitted. Threaded shock bodies or adjusters may be used.
• Any spring up to a maximum spring rate of 500 pounds may be
used."
Your going to have to submit a request to use aftermarket non adjustable struts like tokico hp's and probably eibach pro-kit springs will be the stiffest aftermarket springs. You will have to do some research to find what threaded shock adjusters will fit the strut you may even have to have them made. Basically ride height and spring preload are adjustable but adjustible struts are out. And as for camber plates real racers dont use the adjustable kind your thinking of as they can slip under hard cornering. You will have to make fixed plates at lets say 2-5 degrees of camber.
