alright i was wondering how do i get the factory grille out it dosent say in the instructions... im sure some of yall have the grille so i was jw nvm i got it to work, the right side isnt exactly the same distance off the center post as the left but its miniscule so you can hardly see it unless yer a car nut it looks really nice tho ill get some pics when i get done cant figure out how to get it any tighter on the bottom of that right side tho its about damn impossible to tighten up those flathead screws it came with... any ideas?
perfect chance for you to do a howto!
cell phone pics work too.
alright ill give yall a run down on the install first and foremost then ill get some pics the cell phone cam wont work for this as my phone dosent have a usb port and txting is locked to my phone to save cash lol.
tools needed: 1 flathead screw driver(small),(3/16 of an inch) drill bit, portable drill/ screw driver.
alright the first thing to look for is that black piece of plastic that covers up your hood latch and all if you see where yer windshield washer filler is you should the plastic around it take the flathead screw driver and pry on the center of the black plastic clips easily, you dont want to break them then pull em off and set em in a box or a tray, after you remove all 1900 of these pins its not that many but its quite a few. Move the radiator hose out of the way and remove this piece of shroud i guess it is... now that youve gotten that off remove the other plastic pins from the grille support.. then take a break and drink a beer, alright behind the grille their are some pressure clips push on them hard with your fingers starting from the outside clips towards the inside clips, once you get those off pull the grille forward and voila hard part is done. Then take your marker to mark the holes yer gona drill place the grille in the opening forgot to mention you hsould put the plastic shroud back on for this much place yer grille and mark the spots where yer going to drill and voila thats it pretty much put the clips on the underside of the bumper screw it down then do the same for the top and put all the plastic pins back in and thats it... not perfect but that is the quick write up lol
