You weighed all that stuff? No guessing?
If so this is a fantastic post!
I'm sorry you feel that way.This is so pointless.
"Remember exceeding pressure rating by each psi causes the tires to get very heavy."Suggestion :
Passenger seat
Headrest
Audio deck
The plastic trim found on instrumentation panel
Glovebox
Footrest next to the brakes/clutch
Wipers
-Drain all wiper fluid
-Reduce coolant fluid to minimum level
-Reduce amount of fuel in fuel tank. Normal full fillings are about 40L, instead fill only 10L.
Thats a saving in 30L, which is about approx saving of 48.5 LB.
-Reduce brake fluid level to minimum, if its safe
Drive without shoes/slippers.
Wear minimal clothing - i mean shorts,sleeveless
Edit:
Either fill nitrogen in tires. Or dont overfill air in tires above 33 psi. Instead do some warmup to heat up the tires to increase the pressure inside the tires. Remember exceeding pressure rating by each psi causes the tires to get very heavy. Its best to warmup before the event.
That should save lots![]()
