Can happen, it is just plastic as are many parts on new cars, only retained by clips that engage on a groove on the ball.
Getting it out is simple though. Remove airbox and battery, PCM/ECU bracket (right in the way), pull off the feed line, pull out spring clip on high pressure line, then just twist clockwise 45 degrees and it comes right out.
At this point it could still be the slave, seals could be leaking internally, however i'm confident it's the master. If the master seals were fine, pumping vigorously would likely build some pressure, but i got nothing, and like i said it didn't generate any pressure when i plugged up both ports with my fingers and moved the pushrod. Bellhousing drain hole shows no evidence of moisture, dry as a bone.
Update: Got it working fine, but frankly i find the factory procedure is a little confusing at step 5 where it says "Push the lock pin (1) of the bleeding connector (2) into the locked position". The goal is to bleed the air at that connector through the way the "fitting" is made, it has little detents for the pipe to slide out and ride on the connector, factory says to slide it out 5mm, which is correct, after 5mm movement the pipe just comes out completely. But to do this you actually remove the spring clip by pulling it off, rather than pushing it in. The slave assembly must have some kind of check valve to prevent air from getting that far. Rest of it is straight forward bleeding procedure.
If you look at the diagram of the bleed connector, you'll see that what closes/blocks the bleed nipple is the inserted pipe itself. To open the nipple to allow air out, you remove the clip and slide the pipe out just enough to uncover the nipple passage. Allows air to be forced out and brake fluid to take up the space the air displaced, and get sucked back in. So you don't push the connector in you pull it off then slide the pipe out 5mm but not completely.
This also brings up the idea of removing the damper for more clutch feedback, a more aggressive feeling clutch. However with everything plastic it'd be hard to do properly.
