Did my first oil change and not sure where I should be jacking the vehicle up by? There was a circular reinforced rib on CVT but not sure if that's the right place to do it.
thats what i did and then place your jack stands and voila! oil change on the Note is actually stupid simple as everything is pretty much right there in front of your face once you get under the car including the oil filter which sits right on the front of the engineJust use the pinch welds...
Thanks, I need to do that.PP, you can download the service manual for your Note via the link below. The jacking points are shown on File "A - General Information". Lifting point description starts on page 28.
Yes, oil change is super easy unlike last two nissan (Xterra and Frontier). Both of those seemed to always take some skin off my forearm.oil change on the Note is actually stupid simple as everything is pretty much right there in front of your face once you get under the car including the oil filter which sits right on the front of the engine![]()
Thanks, I used the sub-frame. I bet somebody does it thought.you should never jack a car up by the trans or engine... that is way more static weight than they're designed to handle, not to mention the motor mounts. Use the frame rails
