4X114.3. Not sure about the center bore. What kind of wheels do you plan on getting?
I plan on going to a junk yard and pulling rims of Versa's or whatever vehicle uses the same rims. So nothing special, just a set of rims so I can change my own winter tires to spring/summer tires.4X114.3. Not sure about the center bore. What kind of wheels do you plan on getting?
Hi there I picked up a full set of winter steel rims from Costco for about $45 each not too long ago for my 08 S. You may want to check with them on current pricing as well. I put on them a set of Sailun winter tires at $69 each (looked around for these and got them from local tire shop) for a total investment of around $350. Pretty inexpensive way to have a set of rims/tires for winter use. Just something you might want to consider if you have access to a Costco.I plan on going to a junk yard and pulling rims of Versa's or whatever vehicle uses the same rims. So nothing special, just a set of rims so I can change my own winter tires to spring/summer tires.
