hello everybody i have a question, what is #1 and # 2 for?? mi V is a 2009 1.8S HB
I installed OEM fog lights, and they worked just fine. I also had the plug. I brought up this concern a few months ago, and no one knew what it was for..... And yes, #1 is for heated mirrors.The white thing is for the heated mirror relay. I'm assuming if you had heated mirrors there would be a blue(?) relay plugged in there. The other one looks like it's for fog lights. Only reason I say that is my old nissan came pre-wired for fogs and it used a similar plug.
http://www.nissanversaforums.com/general-technical-electrical/2406-fuse-module-locations-pics.html
Ok so it's not for the fogs. I too have the plug and I have a 1.6 model. The mystery of the little connector under the dash continues . . .I installed OEM fog lights, and they worked just fine. I also had the plug. I brought up this concern a few months ago, and no one knew what it was for..... And yes, #1 is for heated mirrors.
Can't be the tweeter cause when my parents had the Versa SL with convenience package, the tweeters have two wires, and the connector is brown, not white. I can't remember if they had the white connector. I wanna say they did, cause I think I would have figured it out.Ok so it's not for the fogs. I too have the plug and I have a 1.6 model. The mystery of the little connector under the dash continues . . .
In the fsm here, http://www.nicoclub.com/FSM//versa/2009_Versa/PG.pdfpage 39 shows the harness. I can't tell which connector it is though. Might possibly be for the tweeter. Maybe someone else can take a look and determine.
