1 - 20 of 21 Posts
I never had this happen before or seen anything like it. I went to rotate my tires and I take the lugs off the back wheel and the wheel would not come off. It was stuck on the hub. I kicked and hit the tire with sledgehammer. Still did not come off. I soaked it in wd40 and tapped on the rim with a hammer yet still nothing. My brother had to lay under the car and kick outward to remove the wheel. This was only on one side. It was very odd.
Anyone else ever have this happen? I hope I do not get this every time I try and remove a wheel. I can't wait to run down the rubber on these tires so I can put on my altima wheels. I just hope they fit :).
Did you see any debris on the hub when you removed it? Clean the hub and the inside of the wheel that touches the hub. Spray some brake cleaner and use a scouring pad or brush, so it don't stick on when you have to remove them again.
Nope I didn't notice anything on there. This was the first time the wheel was ever removed from the factory. Too late to do anything to the hub as it's back on :). Thanks for the advice though.
I rotated my tires for the 1st time since the factory, and they poped off just fine. They actually, once in air, just fell off, lol!!
This is the joy of living in new England with excess amount of sand and salt on the roads.
NO NEED TO WORRY, very common
this is why I always tell EVERYONE to torque there wheels with no more than 90footlbs of torque.... recommended is 80lbs (but that is for OEM lug nuts)... after market lug nuts I always give it a tiny bit more
my method, grab another wheel/tire and hit the stuck wheel with it... :) never fails
I always put a light coat of Neverseeze on the mounting surface as well as the stud threads. I know there are plenty of people who tell you NEVER to use neverseeze on wheel studs, but keep it off the tapered seating area, and you'll be fine.
I agree about the Never-seez, don't leave home without it. Another thing to try if it happens again, loosen the lugs a turn or so, and roll the car forward and back a couple of times. This may loosen it. Car will have more force than a hammer and the wheel won't get dented. I have to do this sometimes on my truck with aluminum wheels. Another thought, is it the proper wheel?
Discussion Starter · #10 ·
The wheel I had stuck on was the original wheel that came from the factory. It was the first time removed.
that happened to me too, my right rear wheel wouldnt come off, so i kicked it off haha. but it happens to a lot of people
I have a 2020 SV and have been hearing 'stories' about some manufacturers going with 2 piece lug nuts (mild steel core with chrome plated cap). The core corrodes over time swelling the cap so that lug wrench does not fit. The 'fix' is to replace the 2 piece lug nuts with old fashioned one piece, solid, chrome plated lug nuts BEFORE they corrode.
Does Nissan use such 2 piece lug nuts?
Thanks in advance for any help.
Stuck wheels are super common, especially with steel wheels. I either kick or hammer them off from the back with a dead blow mallet. If that doesn't work a big pry bar from the lower inside always works but you have to have room to pop it off like that. It's corrosion, not wheel tightness that causes the problem.
To combat this, I use some brake caliper grease around the hub. Always put it on both sides of the brake rotors as well.
Never have any problems removing wheels or rotors.
Also use a little on the lugs to keep corrosion to a minimum there too.
I used to grease the hub surface until I had to use those tricks next time I saw that car again or other ones you have to wrestle off that have grease on them already.
The general rule is not to put grease on the studs, and if you have to, put a litt on the nut. It has to do with the lube changing the torque of the fastener when it's tightened. Who knows. I personally hate anti-seize and grease on bolts. People loooovvveee loading it on stuff. It just makes a mess, and living in the rust belt myself, I don't run into trouble too often with bolts not coming out. An impact and torch makes quick work of most everything!
If you like working on your own stuff and ever struggle loosening bolts, get one of those mini oxyacetylene torch sets. You'll wonder why you waiting so long to spend a few hundred bucks instead of being frustrated.
I don't live in the rust belt any longer, but what always worked for me was putting a coat of antiseize on the wheel, where it contacts the hub. I would put some more if I removed the wheel, i.e., rotation, puncture,etc.
Good luck!
1 - 20 of 21 Posts
