I recently popped a stock tire and damaged the rim so i’m looking for upgrades. I found some sonata rims and tires. They’re 205/60/16 and i drive a 2008 hatchback
Hyundai Sonata rims? If so, those will not fit as they are 5 lug, while the Versa is a 4 lug wheel.
Stock 16" tires are P195/55/16.
They should fit. Not sure if you will have any issues with offset though.
I would also look at wheels from the Sentra, Versa SL, or Cube as well.
Check www.car-part.com as well for wheels.
Also note, they are equipped with winter tires, so you will need to buy another set of tires, or wheels/tires in the spring.
Correct me if I'm wrong but the Versa Notes are 4x100 so the 4x114.3 won't work. The tyre size shouldn't be an issue but I can't say for sure. My setup is 205/45/16 16x8J ET0, and I have no issue with clearance on stock suspension.
Gen 1 Versas (07-11/12 Hatch) are 4x114.3.
One other thing to keep in mind is that unless you reprogram your PCM to compensate for the larger tire circumference, your speedometer will read about 5% slower than you're actually running. (It will show 60mph and you're actually running closer to 63-64mph)
