Wind stability
1 reading
1K views 10 replies 8 participants last post by  SlickVersa
#1 ·
I am driving a friend's 2015 versa note. This area can have high winds, often up to 70 mph and/or gusting winds. Due to being fairly light and boxy, I avoid driving it on highways when windy.
Is there anyway to increase the stability of it in high winds?
#5 ·
As someone who drives Tractor-Trailers, I would not be driving ANYTHING in winds that high.
Even a loaded semi can go over in winds that strong.
For that car, I would put a couple hundred pounds in it and hope for the best.
Thanks. A couple of months ago there was no wind, but I got a gust that pushed me 3 feet before I recovered. Even in town has sometimes been bouncy. I used to drive I 80 between Laramie and Cheyenne in a heavy sedan with no trouble, but I wouldn't drive it if the roads were icy the wind could slide you off the road.
#9 ·
the lighter the ride ..... the more MPG .... the less stable
the heavier the ride .... the less MPG ... more stability
If you want stability ..... buy a F250.
If you MPG then grip that steering wheel and keep her under 70mph
The first suggestion I give to increase MPG is to reduce weight.
#10 ·
I added 250 lbs of sand bags in various areas of the car. It definitely helped with the wind. It even had a smoother drive in low wind. By luck, I got back to town before the wind got extremely bad. For a few miles I was driving into the wind and could barely accelerate. For the last 22 miles I took a non interstate route that had a ridge blocking the wind. Wyoming is bad for wind 3 years ago one area had 110 mph winds. 1 year, my area had a year average of 65 mph winds. Thanks for the replies.
