No noises is good. That eliminates problems with the glass, window channels, and regulator. Does not quite eliminate the motor though.
Start with the switch, as it is the easiest to replace.
Easy way, get access to the motor, and run to 12 volts leads from your batter, to the two prongs of the window motor, if it moves then you know it's not the motor.
You can also check the switch using a multi-meter.
Either way, you are going to have to open up the door panel.
Related Threads
115.5K posts
20.1K members
Since 2008
